A little help please???
  • DRTSRFR
    • May 2008
    • 1836
    I have a thumping coming from the rear of my ’92 cab. I have replaced both wheel bearings, the diff., and halfshafts. The noise is rhythmic and matches the wheel speed. I also checked the e brake assemblies and everything looked ok.
    As I was spinning the driveshaft, I noticed a light metallic sound at the tailshaft of the tranny. As I look between the guibo and driveshaft flange, I can see what appears to be a yellow zinc retainer of some sort, which is loose. It looks very much like the rear axel nut lock ring. My questions is: Does any one have a pic of the forward portion of the driveshaft? I need a visual before I take the entire bottom of the car apart.
    TIA!
    Suspension tips here...
    http://www.r3vlimited.com/board/album.php?albumid=757
    Check the condition of the rubber mount of the CSB. I'm guessing that you will find it has damage, which means that you need to replace both the CSB and drive shaft. You may also need a new guibo.
    • 87-325ic
      • Apr 2006
      • 1198
      sounds like from your description the rear flange nut on the transmission may be loose..
      other than that, from the symptoms i would say its the guibo and/or csb
      • DRTSRFR
        • May 2008
        • 1836
        Thanks, yeh, that was what I was worried about. It's been a couple of years since I pulled a tranny and I couldn't picture the assembly in my head.
        • DJB
          • Oct 2005
          • 195
          Do you mean the output shaft locking plate? You can look up the part number for a picture.
          23-21-1-490-120 Safety plate/Lock plate, driveshaft output flange, $0.85/$1.33
          If it's loose, you should take off the flex disk (yes, a PITA) make certain that the nut hasn't come loose. If the output flange isn't clamped tightly, the splines will wear. You'll need a new transmission to fix that problem.
