OK I have an 86 325es and I am putting in the 2.5 i engine. Are the transmissions for the eta and the i the same other than the dual mass vs single mass flywheel?
5 speed transmission question
your speaking of the getrag 260 ?3 pedal club
200,k+ club
cabrio club
port-matched- polished- purring www.BMWpark.org
</div>
linux since 1999 -
yes they are the same
the eta trans has bungs for the crank position sensor and tach sensor (getrag 260)-Andy
Don't want to start a new thread...so...
Hopefully OP won't mind a minor diversion, but this follows with the subject heading that was a general subject...
Can anyone in here that has extensive knowledge of the E30 history tell me about the different gear ratios for manual transmissions that came on these engines for the M20 engines?
Is it just one gearbox and therefore one set of ratios that came through all the years, or, where there different ratios for different years?
Alex.Comment
This should help Alex, though where it says G260 under the 90/91 318iS column, it should read g240. The ratios are correct as far as I can see though.
RTFM:http://www.r3vlimited.com/board/showthread.php?t=56950Comment
RE: Thanks
Got the answer.
Appreciate the link, very informative.Comment
