I have 1990 320i manual with 200.000km on the clock...
my problem is rear end clunk when clutch is depressed quicky mostly when going very slow or in reverse also there is some vibrations when going 30-50mph then it goes away...
some of you said before that some u-joint is kinda big problem on these car so maybe mine is fooked?
Is this part repairable or used driveshaft I need to find
