Currently in the middle of an auto to manual swap with my 89 325is. Everything has been progressing smoothly until I tried to mate up the trans to the M20. I am using an M20 clutch and S52 pressure plate. The splines are connected as the output shaft spins when I hand crank the motor, but there is about a 1" gap between the transmission and motor. Any ideas on how to get it to press together?!
Seems like it should be simple and I have lowered it and put it back up about 4 times now to no avail. Thoughts?
Thank you!
Thank you!
