Cars that come w/ Getrag 260?
  • crazy_hotrodder
    • Sep 2004
    • 14
    I don't see anything on the web that blatantly tells what cars came with the Getrag 260. I remember that when my auto started to go out, I took it to a shop and the guy told me that my trany was also put into a bunch of volvos. I was just wondering if that was the case w/ the 5-speed. Even on top of that, what e30's came w/ the 260?
  • Jarvis
    • 2132
    In the U.S., all E30 325i/is' with a 5spd are Getrag 260s.
    E30 325ix's use a unique Getrag 260, because of the transfer case/front+rear differentials in the AWD system
    E30 325e's used Getrag 260s, but I do not believe that these bolt up to the 'i' (M20B25) motor. Also, IIRC, these early 260's for the 325e's have weaker syncros so they're not as good for fast shifting when paired with a higher revving/ higher horsepower motor.
    • Sean
      • 5793
      Is what you said about the Eta's 5 spds true, having to do with syncros? And, would this include a Super Eta?
      That's the first I've ever heard that.
      - Sean Hayes
      • Jarvis
        • 2132
        I'm not positive. I heard that somewhere on this board a while ago. IIRC, what I read here was that the older 260s on ETA engines don't match up directly to 'i' engines, and that they have slightly different internals.
        Please, if someone knows FOR SURE, correct me if I'm wrong. No one else was posting in this thread so I figured I'd toss in my two cents, from what I can remember.
        And about the super eta... I have no idea. I'd be interesting in finding that outmyself. If would make sense for the '88 super eta's to have the same 260 as the 'i's, but then again it still has the 2.7 block just like the old regular ETAs. :idea:
        • Jordan
          • 12916
          The 325e 260's bolt up to a 325i without any issues. You just have 2 sensor ports open because the 325i has its CPS at the front of the engine.
          https://mtechniqueabs.com/
          • Jarvis
            • 2132
            Then is it the 325i 260 that won't bolt up directly to the 325e engine?
            I think I just mixed those up.
            • Brew
              • 3060
              Nevermind.
              '91 318is
              • Sean
                • 5793
                But, what about the syncros thing?
                - Sean Hayes
                • gstuning
                  • 833
                  Note : ix 260 boxes are indeed regular 260 boxes,
                  just ask oskard he has one and no transfer case on it and is running it on his 320i ´89 motor with E21 323i flywheel and M20 starter and 320i driveshaft
                  Gunni
                  @ Prodrive / Aston Martin Racing
                  • Jordan
                    • 12916
                    No, the 325i 260 will bolt right up to a 325e without any issues. Only problem is the 325i 260 doesnt have the 2 sensor ports. It's not a big issue however, because the vasting bosses are still there. One need only drill 2 holes.
                    • Speed25
                      • 39
                      Which Getrag did the M10-engined cars come with? Were these 260s as well or something else?
                      • damionphillips
                        • Mar 2005
                        • 47
                        Check in the FAQ to see a couple of VIN# Decoders...you can pull your car's info from these.
                        • Madhatter
                          • Oct 2004
                          • 966
                          They changed the layshaft bearing design when they pulled the 260 from service for a couple of years. The new box got the upgraded cover (with the cooling fins), a combination roller/needle layshaft bearing and the newer aluminium shift forks (the reinforced ones, not the first lot which are known to snap).
                          That would be about the only difference, the m30 ones had thicker gears though (because of the torque difference).
                          Just a little project im working on
                          - http://www.lse30.com -
                          • Digitalwave
                            is a poseur
                            • 6302
                            I want to say 240. I know its not 260 though.
                            RISING EDGE
                            • DanGillan
                              • Mar 2004
                              • 4061
                              so did all manual e30's have an overdrive 5th gear?
                              Dan
