Stuck Clutch Pedal
  • McGyver
    • 4636
    Stuck Clutch Pedal
    Today when i was driving every once in a while the clutch pedal would stick right above the floor and felt like it was engaging WAY before it should. Also when i pressed the pedal to the floor i couldnt get it to go into any gears from neutral. I've been pulling it up with my foot and then it works again for a while. This is only in first gear though.
    I've read about clutch master/slave cylinders and i dont see any fluid in the car, but the brake fluid is leaking out somewhere because the resevoir keeps getting low.
    I need to drive 240miles tomorrow from my mom's house to mine where i have tools. is it safe? and how can i test the individual cylinders?
    thanks.
  • SpecM
    • Oct 2005
    • 4531
    leak in the slave or clutch line
    get under the car and look
    1989 cirrisblau-metallic 325i
    • 2.5-12
      • Jan 2010
      • 1814
      possibly a bad clutch master as well -- can exhibit weird behaviors.
      1991 E30 M3 Brilliant/black - S54B32/5M
      1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
      2011 E82 1M VO/blk/6M
      1991 E31 850i red/grey/6M
      1997 F355 spider red/tan/6M
