i drive shaft in an eta???
  • offwhiteghost
    • Jan 2010
    • 174
    [UPDATE] i got the drive but it doesnt seem to match. the replacement drive shafts bolt do not line up with the trans (guibo is way smaller), it also has a metal sleeve around it.
    did the guy even sell me a shaft off an 325is?
    Replacement on the left, original on the right
    SSPX0077 by offwhiteghost, on Flickr
    SSPX0074 by offwhiteghost, on Flickr
    guibo and metal sleeve of replacement
    SSPX0078 by offwhiteghost, on Flickr
    [ORIGINAL POST]
    i know this may have been asked before but i didnt find it, sorry.
    The drive shaft in my 87 325 is dead and i found one off a 87 325is, both manuals.
    Would this work??
    Yes.
    • Jargo
      • 490
      Yes.
      Owned lots of E30's
      Currently sporting:
      85 324td
      86 535i
      89 635csi
      Feedback thread
        • 37829
        As long as they have they have the same size guibo.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • offwhiteghost
          • Jan 2010
          • 174
          [UPDATE]
          See first post
            • 37829
            If it's the bigger size guibo it's an Eta driveshaft that was only offered in one year (87?). You can run it without that balancer thing but if the flange is bigger it will not work of course.
            Grover Beach, CA
            www.BimmerHeads.com
            • jeffw
              • 1087
              whats the year of the original and the year of the replacement? Etas should have for the most part a small guibo. there is larger ones and they are obviously larger. its not a small difference
              • offwhiteghost
                • Jan 2010
                • 174
                Original is an 87eta out of a 325, the replacement (i was told) is an 87 325is
                  You can use that drive shaft by changing the output flange on the transmission.
