5 speed Q... Dont worry I'm a noob, and have my flame suit on
  • Bglad
    • Jul 2010
    • 562
    OK so are all the 325i 5 speeds the same as the Eta's?? What is different if not?? Thank you come again.:firehop:
  • SeriousBusiness
    • 428
    Didn't they all have G260's?
    1985 RX7 - Badassery Exemplified.
    1989 325is
    -Tom
    • Bglad
      • Jul 2010
      • 562
      I dont know, that's why I'm asking.
        While both the M20B25 and M20B27 engines both use Getrag 260 transmissions with the same gearing, there are some differences in the transmission casings. ETA cars have the timing reference sensors mounted in the bell hosing, requiring holes in the bell housing for the sensors, and early ETA transmissions will accept the sheet metal shift console.
        • Jargo
          • 490
          So you can use an early trans in a late model car, but not the other way around since the sensor holes would not be present.
          Owned lots of E30's
          Currently sporting:
          85 324td
          86 535i
          89 635csi
          Feedback thread
          • Bglad
            • Jul 2010
            • 562
            If it were an Eta....
              Sort of correct. The lack of provision for the late shifter would require the use of the early shifter with the sheet metal console.
              • StereoInstaller1
                GAS
                • 22679
                There is also the issue of the output flange being different.
                How about this for an answer: both transmissions are the same inside, but have some differences outside.
                Closing SOON!
                Thanks for 10 years of fun!
                • Jargo
                  • 490
                  What exactly is missing, and is it not possible to retrofit a late shifter?
                  Owned lots of E30's
                  Currently sporting:
                  85 324td
                  86 535i
                  89 635csi
                  Feedback thread
                  • xwill112x
                    • Jan 2009
                    • 4236
                    just buy a used tranny from the same type of car you have, (i,e, late, early)
                    problem solved.
                    • Bglad
                      • Jul 2010
                      • 562
                      A taco is not a burrito.
                        The early trasmissions don't have the tabs on the top of the transmission that anchor the front end of the aluminum shift console.
                        • F34R
                          sLaughter
                          • 12376
                          How about you tell us the year of the e30 you are using. That would narrow it down.
                          Instagram: @BWeissLeather
                          Current cars:
                          ~ '87 325 M30B35 swap
                          ~ '87 535
                          ~ 01 540 Msport 6spd
                          ~ '06 X5 4.8is
                          • OldGray320i
                            • Aug 2009
                            • 19
                            And the other way around as well?
                            I put a later trans (by two months, big problem, go figure...) in an early sheet metal mount car.
                            ALL parts that could be replaced EXCEPT the shift lever itself were replaced, and the shift action is terribly sloppy.
                            Is the shift lever my issue?
