auto to manual
  • greekfreak
    • Jul 2010
    • 106
    auto to manual
    i was wondering can you swap out the auto trans in a 325i to a manual? or is it to much work or will it not work at all please help out thanks
    Im Greek thus the name :D
  • Wishno87
    • 6025
    It works. Many people have done it. What year is your car?
    • khoala
      • Dec 2009
      • 15
      it's literally a 5 second search. there's tons of threads on this already. it's possible, here's one thread to start you off.
        • 37834
        With the right parts everything bolts up and works. No custom modifications needed.
        Grover Beach, California
        BimmerHeads.com
        • JTapper
          • Sep 2009
          • 847
          It's not too complicated. I did mine over two days, total time of around 12 hours.
          I swapped out transmissions a week later and did it in 4.5 hours.
          Just search around and you'll find all the answers you need. The little tricky things are bypassing the park/neutral interlock (there is a diagram just search) and enabling the cruise control again if you so desire. Just know that if you want to use cruise control again, you'll need to install a pedal cluster that has the clutch switch on it. Mine came out of an e34 528e.
          Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
