Transmission mounts
  • thebutcher37
    • 2877
    Transmission mounts
    SO after having my Flex disc blow out on me... i got a replacement and Im back on the road.. just to realize 2 days later that my transmission mounts, well One at least have broken... err actually ripped in half to be specific.
    Anywhay... Before I noticed the broken transmission mount, my car had been slipping (clutch) idling funny/shakey... It wouldn't slip on take off only from 1-2 gear shifts during hard acceleration.. only recently when decided to do a burn out did it slip very badly in 1st... after that I drove it home jacked it up and found the broken mount..
    Now I want to ask...
    The broken mount would lead to my clutch slipping right?
    Could the broken mount also cause a wierd/rough idle..?
    my car shut off a couple times right after starting it up in the Morning.
    Thanks for any info Holmes!
    Transaction Feedback
  • dkbmxer002
    • Nov 2007
    • 1389
    lol my tranny mounts have been fucked for a while. i keep meaning to replace them. i zip tied them for a bit as a ghetto temp fix.
    • thebutcher37
      • 2877
      HA.. never thought of that... only one is broken.... i haven't driven my car in a couple days...
      maybe.. ill try this! just so i can drive it back n forth!
      • Danny
        • 14216
        Originally posted by thebutcher37
        Thanks for any info LBJefferies!
        Fixed
        • DJB
          • Oct 2005
          • 195
          A broken mount wouldn't cause the clutch to slip. How old is the clutch disk? How many burn-outs does it have on it?
          A common cause of a broken transmission mount is installing the transmission support bracket backwards. For some reason it just *looks* as if it should go back on the wrong way. Swap right for left and see if it fits better. And consider yourself fortunate to have not broken mounting ear on the transmission case -- that's a much more expensive failure.
          • thebutcher37
            • 2877
            The Sach's clutch "kit" Disk/cover/Bearings are Brand New... few hundred break-in miles.... 4 burn outs
            Im thinking the shop i had work on my trans fukd shit up! broken mount/ tore up Flex Disc/ slipping clutch... I found oil leakage on the bottem of my case... thinking this could be a culprit. For what its worth... I did not have my flywheel resurfaced...
            UPDATE.. YES the fucking Idiots at the Half-ass Transmission shop put my brace on backwards.... i went under to replace them a moment ago... and im like.. damn this shit looks backwards... googled a picture and yeah mines is on backwards!!!! im furious Ive had nothing but bad problems with this shop.... Im so fortunate to have gotten a refund.. but FFFFF /Rant
            • dkbmxer002
              • Nov 2007
              • 1389
              wait so a shop did it and you have these problems? they left a mount broke and didn't tell you? shit leaks? i would not go back there...
              • thebutcher37
                • 2877
                The transmission shop had my car for about a month, rebuilt my trans from two trannies that i had, one was the original trans that went out 1.5 years ago and the second wasn't in as good condition as it was said so when i bought from a member here on R3v...
                they took a look at both transmissions decided to make one good from the two and replace parts along the way... so i paid in full the next day and after having the car back 3 times over the month, the end result was that the gears would grind in 4th.... so i was like this is no rebuild... fix it I have a 4 month warranty!!!
                so they "tried" to get it right but 3-4 days after I get my car back and they tell me that i will be getting a full refund.... Happy I was at the time...
                now 2-3 weeks later i have a transmission that seems to be leaking (which it wasn't before), a slipping clutch that was brand new when installed into the so called rebuilt transmission, a broken flex disc (which was probably put on wrong), and a broken trans mount (which was for sure from them putting the brace on backwards).
                Im back on the road because i got the flex disc and mounts replaced, but Im going to need to drop the transmission in order to see why my brand new clutch is slipping.
                • E30Gus
                  • Jun 2008
                  • 781
                  If they didn't seal the transmission properly (input shaft), it is possible that the fluid is leaking into the clutch area and making it feel like the clutch is slipping...well it would be slipping if this happens.
