When I was researching what T/O bearing to use on my 323 fw, the comparisons always showed them standing up, to show the overall length. Though I don't know why the part in the fork would matter, the measurement you are talking about seems to be the more important one. Perhaps jlevie will pop in and school us.
I thought the throw out bearings for the e/i were the same.
They are listed on Pelicanparts as the same anyway. I bought a bearing a long time ago to replace with my e and then used it with my i swap. works fine and I could not tell any differences between the two.
It depends on what flywheel is being used. If you have a dual mass you need a shorter T/O bearing and if your using a single mass you need a longer T/O bearing to reach the diaphragm because the whole assembly is thinner.
