Not seeing a post...changing diff's
  • Bimmerfanatik
    • May 2004
    • 5349
    Just picked myself up a 3.25 LSD diff, but unsure as to what is entailed in the swap. I have the stock open diff, 2.89 afaik, so is there a writeup or can someone walk me through it?
    Thanks!
  • DanGillan
    • Mar 2004
    • 4061
    unbolt the old, bolt in the new, that's it. nothing thats not straight forward at all. or pay me to do it sukka ;)
    Dan
      • 34844
      use a jack, and don't drop it on your hand. it weighs somewhere in the 95lb range. also use locktite on the upper bolts because they like to come out...
      • Bimmerfanatik
        • May 2004
        • 5349
        Dan, you have trouble taking your own valve cover off (remember Hanscom? :))
        I don't know if the cases are the same with it being a 3.25.
        • Jonathan M3
          • 1837
          The cases are the same but depending what car it came out of, you may have to swap rear covers and output flanges with your stock diff.
          '05 E46 M3 Imolarot/Cinnamon - CURRENT
          '98 E36 M3 Estorilblau/Dove - SOLD
          '90 E30 M3 Brilliantrot/Black - SOLD
          SRS BSNS Motorsports - 24hrs of LeMons Racer
          • Bimmerfanatik
            • May 2004
            • 5349
            That's more of what I was getting at...a how to for this. I'm assuming it's out of a 535is, since that's the only car I can think of that came with it, right? Might be wrong...someone here will let me know if I am :)
            • Chris E30 Cab
              • 866
              ....and don't forget to fill the new one w/ limited slip fluid :)
              • Bimmerfanatik
                • May 2004
                • 5349
                Any recommendations? I can't wait to put this thing in... :)
                • Chris E30 Cab
                  • 866
                  there are many brands, but just make you use the fluid for limited slip differentials.....it is different than the fluid for open differentials.
                  • Bimmerfanatik
                    • May 2004
                    • 5349
                    good to know...thanks for the heads up :) Two wheel mullet-headed camaro burnouts, here I come!!!
                    • Bimmerfanatik
                      • May 2004
                      • 5349
                      Can you give me a better idea of what's involved in this? Or anyone else? Thanks!
                      • tonytony
                        Knee deep in poopie
                        • Jan 2004
                        • 3498
                        be prepared for some nice dirt in your face and hair, many hours under the car. I just recently did this with Tom(mot) and it took us forever to line up the bolt holes right. It's pretty straight foward really, just get a friend you help you out. Dont forget to drain and fill the new diff before you put it on the car. hope that helps
                        • BS87
                          • 1606
                          Is this really neccesary? I just threw some Redline 75w90 or whatever in there, completly forgot about that lsd additive stuff.
                          • tonytony
                            Knee deep in poopie
                            • Jan 2004
                            • 3498
                            it already has it in the fluid
                            • Bimmerfanatik
                              • May 2004
                              • 5349
                              Going to be doing the swap tomorrow...any last pointers? I have the 3.25 sitting alone - just have to swap the cover and output flanges once the diff is off my car, drain, and fill - once it's on the car though, right? (The drain/fill)
