High lock diffs
  • Jean
    • 18228
    High lock diffs
    Who makes these OTHER THAN OBX and Quaife, any other choices?
    The 25% lock diff is not working out that great for me on race tires.
  • Holland
    • Nov 2008
    • 7212
    I hear with 4 clutches you can achieve 40% lockup. My friend had that in his obd1 S52 car and had no problem with traction. He was running bottle caps on 60 series winter tires with very worn tread.
    Originally posted by DEV0 E30
    • Mike The Bavarian
      • 488
      diffsonline. My buddy works for them. probably one of the biggest diff companys in the bmw world.
      • Jean
        • 18228
        Anything else out there? diffsonline is pretty expensive from the quick look
        • Blackangusinc
          • Jul 2010
          • 244
          971-295-7077
          91' 318i
          • lennon
            • Jun 2008
            • 1416
            anyone using a bmw viscous diff? how are those?
            • Kershaw
              • 11822
              that would be interesting. getting the rear diff out of an ix.
              they are 3.91 and are variable lock up depending on traction. 10-100%.
              im pretty sure it'll bolt into a normal e30 no problem. the rear of the ix is the same as any other e30.
              AWD > RWD
              • Blackangusinc
                • Jul 2010
                • 244
                Has anyone done this? Pictures?
                971-295-7077
                91' 318i
                • nrubenstein
                  • 3148
                  Viscous diffs are not durable. Please leave them to the iX people. You'll burn up the VC faster than you'd believe possible with that kind of abuse.
                  The cheapest upgrade is an MZ3 diff. Of course, you have to be geared for it. Personally, I recommend sucking it up and going to diffsoline. The diff they built me is the best thing about the race car.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                  • FredK
                    • 14763
                    Metrix Motorsport is now Precision Gearing. You can get a 40% diff for $850 or so.
                    Yoshi and Mitch wrote about diff modding a little bit on e30tech. After you filter through some of the noise, there's some useful information there.
                    The BMW helical diff as found in 98+ Z3s is made by Zexel in Belgium, and is a nice way to get a silent, low mileage, rust-free diff in a few different ratios that are interesting to E30s.
                    • Jean
                      • 18228
                      What ratios and lock rates were available on Z3 diffs?
                      This is still something I need to do....
                      • z31maniac
                        • 17566
                        FredK, when you say "helical" does that mean it's like the "Torsen" diffs found in Miatae?
                        www.gutenparts.com
                        • Wh33lhop
                          • 11705
                          Yes.
                          paint sucks
                          • z31maniac
                            • 17566
                            Oh re-he-heealllly?
                            What ratios are available?
                            www.gutenparts.com
                            • nrubenstein
                              • 3148
                              I run a Z3 diff in my swap car. It has pluses and minuses. The big problem is that if you lift a wheel or get in a very low traction situation, a helical/torsen/quaife diff goes open. You can abuse the parking brake to put some load on it if you need traction help in the snow, but it's not great in performance situations.
