Ebay Clutch, 4 Questions.
  • 6gen91
    • 712
    Is this a good clutch first of all?
    Will it fit on my 2.5 block/trans?
    And is it for the dual mass flywheel?
    Will i need a different pressure plate?
  • e34john
    • Apr 2006
    • 3599
    Nobody on here will recommend that clutch. Get the Sachs kit for like 250 that has the throwout bearing and pressure plate and be done.
    • e34john
      • Apr 2006
      • 3599
      Just checked the rest of his stuff, he has the Sachs kit for around 200.
      • 6gen91
        • 712
        what exactly is wrong with that clutch?
        what about this one?
        • CabbE30
          • Aug 2009
          • 2358
          http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
          I got one of these with my gripforce clutch kit when i did my 5 speed swap. No complaints. No slipping or anything so far after 3k miles. Everyone says my clutch is grabby or firm but thats the pressure plate/ their lack of driving ability.
          • DaveSmed
            • Apr 2007
            • 1407
            Why do people always want to over-clutch their cars?
            I have probably double the power of your car going through a stock clutch. That is pushing things a bit, but no problems with grip at all.
            -Dave
            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
            Need some help figuring out the ETM?
            • F34R
              sLaughter
              • 12376
              Grip force makes a good clutch, my friend is running one on his M50 swap with no issues. I personally bought the Sachs.
              You can get the whole sachs clutch kit for 140 shipped off ebay from a power seller on there.
              PM White325is on here, he knows the seller.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • B3M2W5
                • 283
                The F1 clutch isnt bad i ran it on my M50 cuz i got a disc free.
                Rec saches but the 6 puck does the job never had any sliping.
                The only thing i would say negative is that the pucks are thiner and will wear a grove that is smaller then the stock clutch in the flywheel.
