Whenever im on the ground, the trans spins freely but the driveshaft stay stationary and there is a metal on metal clinking. When the car is in the air, the rear tires seem to spin barely. What Could this be please help thanks!!!
Trans/Driveshaft Problem!!!
Ich gehöre nicht zur Baader-Meinhof Gruppe
Originally posted by Top GearJust imagine waking up and remembering you're Mexican.
Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
If the drive shaft doesn't turn when the transmission is in gear and the clutch is engaged there is a problem between the drive shaft and engine. Unless the guibo is missing that means a bad transmission or a bad clutch on a car with a manual transmission, or just the transmission if an automatic.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
it looks like u are looking for a new tranny had the same problem at work last week but with a automatic tranny but its the same principle.Comment
