I have an issue going into gears at certain RPM's (much like clutch-less shifting) and first thought it might be the slave, master etc etc everything checked out. Rebuilt everything in my shop up to spec, tightened up the shift linkage etc thinking maybe that was the problem, but...
the weird thing is now that everything is new and tight here's the situation.
At a stop light in neutral, depress clutch to go into 1st and the car starts rolling forward a little and it's hard to get in gear as if the clutch isn't all the way down. Could this be a result of bent/misaligned shift fork?
Thanks in advance,
-John
Thanks in advance,
-John
