1988 E30 M3 G265 onto an M20B25?
  • robmpulse
    • 25
    Okay, I have searched until I was blue in the face. All the info that I found did not leave me to a conclusive answer.
    If I cross reference the part number of my transmission via realoem, it lists the E30 M3 Coupe as well as my 1993 325i.
    However, when I searched realoem specifically for the tranny for an E30 M3, it shows it as having the getrag 265 transmission, instead of the 260 that my car is listed to have.
    I happen to need a new trans, and have access to a getrag 265 that was left over from a swap.
    Just need to know if I would have any issues using it. linkage, driveshaft, etc.... would it all bolt up?
    I have a late model 1993 E30 325i.
  • PeaveyBassist
    • Sep 2004
    • 3511
    Old thread BUT... Your 265 will not bolt up to an m20 or m50.
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
    • LJ851
      • 7919
      Yes it will.
      Lorin
      The M30 is God's engine.
      • Todd Black 88
        • Oct 2007
        • 3449
        So so so wrong.
        It will bolt up if you switch the bellhousing to one from a US spec 528e from..........either 1982 0r 1983 iirc. I forget exact year.
        The 265 was an option on that year of e28 528e.
        Originally posted by codyep3
        I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
        2001 silver/Blk 325 cabby. SOLD
        2002 325xit Sil/blk. SOLD
        2010 F650gs twin
        • PeaveyBassist
          • Sep 2004
          • 3511
          Then you would have to find someone with that bellhousing for sale and swap to make it worth it. What I was saying was, the way his 265 sits it will not bolt up to his m20. Good luck finding that one bellhousing!
          DaveCN = Old Man
          • LJ851
            • 7919
            They are not hard to find if you look. Ive got 1 and have passed up several at the 'yard cause i dont need them.
            Lorin
            • weare30
              • 31
              I have the same question.. I have access to a 82 528e a friend is parting out and was wondering if I would have all the nessacary parts to swap into my 84 325e
              • LJ851
                • 7919
                I have not done that exact swap but it should work. The only thing i would be concerned about is the length of the trans compared to your current one.
                Lorin
                • briansjacobs
                  • 1278
                  you will need the proper bell housing and a new driveshaft and you will more than likely want to change your rear diff depending on what gearing you have now. if I had to do all over again I would probably just put in an E36 M3 gearbox as it has a 1:1 5th gear and is cheap
                  Brian Jacobs
                    • 34847
                    why would you want this transmission with an M20?
                    • bobross
                      • Jul 2005
                      • 753
                      Stronger, More Syncros, Shorter Ratios.
                      Need more?
                      I am in the process of getting a ZF S5-31 hooked up with my M20. On top of the aforementioned list, i will gain access to more clutch/flywheel options and power holding capacity, as well as less overall moving parts in the trans.
                      -Greg
                      90 325isT - 12.2 @ 120ish - Dyno Results
                      b18c5 EG Coupέ - 13.5 @ 100ish - Dyno Results
