Okay, I have searched and searched. There is a TON of info regarding this. In addition, a LOT of it is riddled with a bunch of incorrect info as well.
As much as I can conclude... they share the same gearing in all the 260's.
I know I can swap the output flange, as they are different diameters.
What I am not clear on, is the linkage.
I know they are different. Early E to an I, that is. So does that mean I just need to use the linkage that came off the E car? I assume they both hook into the shifter the same, but appear to have different mounting points on the trans itself.
Can anyone clear this up for me? Anyone done this? Thanks.
