Autozone oil for LSD?
  • xwill112x
    • Jan 2009
    • 4236
    Originally posted by MR 325
    Well, this thread is about differentials BUT most Getrag transmissions take 75w90 gear oil too. There are some that take ATF and will have a green label on them saying so.
    pretty sure they all came with atf from the factory?
      • 37833
      No, they did not.
      Grover Beach, California
      BimmerHeads.com
      • xwill112x
        • Jan 2009
        • 4236
        hmm. someone told me that bmw's up until some what recently had atf in them from the factory. guess he was wrong. pretty sure my 318 had atf in it when i drained it. maybe there were certain years or something.
        • E30_(1st Musk)_
          • 2008
          if the 75w90 saids LSD on the bottle, do we still need to add the modifier?
          example:
          http://www.autozone.com/autozone/acc...fier=1437_0_0_
          also MR 325
          is 75w90 recommended for the g260? and is modifier needed?
            • 37833
            example:
            also MR 325
            The friction modifier doesn't need to be added, but you can.
            75w90 or 80w90 is great for the 260 trans as well. No additives for the transmission.
            BimmerHeads.com
            • priapism
              • 1182
              Since we're on this subject, how much fluid does a 3.73 take? About to swap out a diff, figured I'd throw new fluid in there.
              -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
              • slammin.e28
                שמע ישראל
                • 12054
                I used the Lucas stuff. It took about 1 1/2 bottles. Maybe 1 3/4.
                • priapism
                  • 1182
                  Quarts?
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    Quarts?
                    I guess that's what it came in. I just grabbed 2 bottle just in case and used most of them. I didn't look at the volume.
                      • 37833
                      Grab 2 quarts, as said you'll have a little left over. Same with the transmission.
                      BimmerHeads.com
                      • Ryann
                        • 3350
                        I'm using Redline GL-5 without friction modifier in the 318i, no chatter. I used to run cheapo brand-X synthetic 75w-90 + Motorcraft friction modifier in the 2002, no chatter.
                        • E30_(1st Musk)_
                          • 2008
                          thanks, i ended up using redline 75w90 for the diff.
                          and redline mtl for the transmission
                          from what ive heard, you fill it up till its just about to the filler hole, and if it starts to pour out of the filler hole then it is full. I ended up using just a tiny bit under 2 quarts
