I have a problem with my transmission at the moment. When I shift into 4th gear I experience some grinding. However, it doesn't grind right when it goes in as if the synchronizers are bad. It just feels like it wont go all the way into gear. I'll push in the clutch, put it in fourth, then it will grind when I release the clutch. This problem happens off and on. What could be causing it?
Won't go into gear
If I'm planning on doing the Z4 shifter swap for a metal console, will these mounts and hardware be replaced with it? I really have to do whatever it takes to fix this because there's no worse feeling than grinding a gear....especially when its not due to a bad shift.1985 325e - 5000 RPM's of FuryComment
