tranny bolt help!!!
  • E30_(1st Musk)_
    • 2008
    tranny bolt help!!!
    Ok so i drained the oil in my transmission because its obviously the first thing to do when changing oil...
    when i go back to open the filler plug i see that the EFFIN PREVIOUS OWNER
    stripped the hex screw and i cant get enough grip to open the plug..
    what can i do? i cant drive without tranny oil
  • erik325i
    • Jan 2005
    • 3567
    This is exactly why you are supposed to always open the filler first.
    Sorry
    I forgot, does the fill plug use a allen type wrench, or a normal hex wrench?
    • bimmer206
      • 237
      Take off the pan and fill it with oil.
      • Dj Buttchug
        • Jun 2010
        • 7688
        dremel cut a line into the plug. then extract with a large screwdriver or impact driver
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • E30_(1st Musk)_
          • 2008
          Sorry
          i know, this is were i made my mistake because i was to eager.
          its a 5 speed
          well i got somewere to take it tomorrow, and hopefully this idea will work but it seems the prevous owner didn't know when to stop, or loosen it little by little
            • 37834
            Originally posted by E30_(1st Musk)_
            its a 5 speed
            What does that have to do with what he said?
            Also, if your filler plug a hex or allen?
            Grover Beach, California
            BimmerHeads.com
            • xwill112x
              • Jan 2009
              • 4236
              always take out the fil plug before you drain it...now you know why i suppose.
              • E30_(1st Musk)_
                • 2008
                i didnt think the 5 speed had an oil pan?
                i really cant tell, it was stripped/almost looked like a smooth circle.
                lesson leard.
                btw we got oil in there through the drain plug, but in order to take the filler plug out i think ide have to drop the transmission and figure that 1 out.
                • lennon
                  • Jun 2008
                  • 1416
                  did you turn the car upside down to fill the tranny? i can't think of another way you could do it through the drain.
                  • E30_(1st Musk)_
                    • 2008
                    haha ill do my best to explain.
                    we took a funnel and used thick tape around the edge. We then taped the grease gun tube to the tip of the funnel (so if you can imagine a volcano inside the transmission)
                    Then i held the funnel tight against the drain plug and he pumped MTL in.
                    After he was done i quickly pulled the funnel out and he plugged it back up. At max it lost like 3oz. of oil
                      • 37834
                      Wow.
                      BimmerHeads.com
                      • lennon
                        • Jun 2008
                        • 1416
                        jmp auto didn't want to just remove the fill plug?
                        • blackhawkimpact
                          • 2415
                          They sell some special sockets at Autozone. There sockets designed to grip stripped bolt heads.
                          • ttrousdell
                            • Nov 2009
                            • 1770
                            lmao so fucking stupid.
                            The Build:
                              • 37834
                              If your car was in my shop I definitely would have been more concerned with fixing the problem than working around it.
                              BimmerHeads.com
