Reverse Rubs Console
  • NeoMishMoo
    • Jul 2009
    • 448
    Putting my car into reverse rubs the console and shreds $50 vinyl shift boots from bavauto within weeks.
    I recently rebuilt the shift linkage and installed a z3 shift lever, but it still rubs. Do i need to bend the lever? The stock shift leve rubbed too so it shouldn't be a problem with the z3 lever.
    West German BMWs, they just don't make the same as they did before the wall fell.
    ^Case in point: Auto-Repair Technology. Everytime my car isn't starting or acting up I let it sit, sometimes for an hour, sometimes for days. But it eventually fixes itself.
  • KennyT
    • 542
    How close to the console are you in 5th?
    • NeoMishMoo
      • Jul 2009
      • 448
      Pretty good distance. Just not sure how to adjust the whole thing over to the right.
      • KennyT
        • 542
        You heat up the rod and twist it..You should be able to figure it out.
        • redhatpat
          • Aug 2005
          • 656
          Mine did this too after I rebuilt the shifter linkage. I cut and rewelded the rod a little offset - worked perfect. I could never understand why this was needed.
          • AndrewBird
            The Mad Scientist
            • 11898
            I'd start by checking your engine and tranny mounts. They might be bad and the engine/tranny might not be sitting where it should be.
