differential sensor = wrong connector
  • funcrew
    • Jun 2007
    • 1223
    The electrical connector on my new diff is a different style from the old one. Can I swap the old sensor for my old diff into the new one, or do I need to find a pigtail for the new diff?
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
    You can swap the sensors.
      • 37832
      Tim, they are a direct swap. Just take off the two 10mm bolts.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • funcrew
        • Jun 2007
        • 1223
        OK - Thanks. So the two sensors are different. One has the two magnetic (yep - a large glob of metal shavings stuck to the sensor from the puked diff) prongs the same length, the other one has one prong about 1cm longer than the other. I've got them swapped; will drive the car around and see if the speedo seems believable.
        -Dr. Paul Forrester
        • Pussy30
          • Feb 2011
          • 463
          Ive been there, no issues with mine.
