thickness of brand new clutch?
  • kansas-ix
    • Jan 2004
    • 1600
    wondering what the thickness is of a new clutch debating whether my one from other car is good enough or whether I should just buy a new one.
    = what would you replace when you have the tranny out?
    E30 325ix 62k
  • ZiMMie
    • Jun 2004
    • 968
    ill replace both shaft seals.
    www.stancefactory.com
    • nickmp0wer
      • 1427
      what about the seal on the engine. Rear bearing i think its called?
      • Sean
        • 5793
        Rear main seal.
        I'd reccommend changing it. Better to deal with it while you got everything out anyway. Just make sure you put it in correctly. :)
        - Sean Hayes
        • onenicebimmer
          • 139
          Rear main seal.
          what he said...
          • Digitalwave
            is a poseur
            • 6298
            Re: thickness of brand new clutch?
            The clutch, pressure plate, pilot bearing, throwout bearing, rear main seal, any tranny seals that need replacing, and shifter parts that need replacing, tranny fluid, CSB and guibo if needed, resurface flywheel.
            RISING EDGE
