Currently, I'm whining... at least until I spring for a UUC or AKG shifter. My point is (and always has been in this thread), is it is a shitty 20+ year old design and if you are used to shifter in more modern cars then just bringing it back to OE spec may not be satisfactory. It's not for me.
Sloppy Shifter
'88 325is: Diamond Schwartz; 210K miles; Koni SA; H&R springs; poly bushings (sold)
'03 TDi Wagon; 5 spd (Ho-hum DD; 326K miles and counting...)
'64 Morris Mini Cooper (w/e vintage toy #1)
'72 Triumph GT6 (w/e vintage toy #2)
'73 Volvo 1800ES (future vintage restomod project) -
Currently, I'm whining... at least until I spring for a UUC or AKG shifter. My point is (and always has been in this thread), is it is a shitty 20+ year old design and if you are used to shifter in more modern cars then just bringing it back to OE spec may not be satisfactory. It's not for me.1989 325is / 2.7, 274 cam, e30 M3 5-lug
1989 LN106 Hilux / 3.0TD SFA
1974 2002tii / stock
2002 IS300 / 5spd LSDComment
I did a FULL shifter rebuild on my 325i (everything except for #1, 6, 11) and the difference was night and day, fully worth it. I took the time to lower the exhaust and drive shaft so I could replace #14 and the shift selector seal.
I kept the original shifter and it's very nice when it's working as designed. You have to keep in mind these were designed as luxury sport cars, and as such have some tolerance built in with rubber bushings to minimize the vibration sent through the shifter.Comment
I drove a car with a basic short shifter refresh and his felt like new compared to mine. His car had far more miles and a less complete job for far better results.1989 325is / 2.7, 274 cam, e30 M3 5-lug
BMA autoparts has the whole shifter rebuild kit.
http://www.bmaparts.com/item.wws?coo...ntid=bmaparts&Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.Comment
edit: it's not even a great deal. on rmeuro, z3 shift levers are 66.02, and the cup bushing is $4.22, bearing sleeve $6.98, and $0.68 for each of the two clips. instead, buy ALL the shifter bushings a la carte, and pick the lever of your choice. BMA is missing the shift rod joint and rear carrier.Last edited by mkcman17; 04-26-2011, 11:43 AM.1989 325is / 2.7, 274 cam, e30 M3 5-lug
