e30 differential swap options
  • delt266
    • Apr 2011
    • 32
    Hey guys, I've been searching but cant seem to find a definitive answer. I have an 89 325i and a whole 95 M3 drive train. Can this M3 LSD be swapped into the e30 chassis? I was hoping there would be a writeup somewhere, but I cant seem to find anything. Any help would be greatly appreciated!
  • bmwmech1
    • Jun 2010
    • 1075
    The answer is yes and no, Lol! It's not a straight swap, because the E36 diff uses a different diameter reluctor ring and a dual ear cover on the rear. I just modified my E30 LSD by adding the E36 dual ear cover and clearance'd the cover on the inside and machined a .300" spacer for the E30 speed sensor to fit without hitting the ring. You would have to do the exact opposite of what I did. Unless you're comfortable with doing these mods, look for an E30 LSD instead and sell the E36 one to offset your costs...
    Garey
    • delt266
      • Apr 2011
      • 32
      Wait I am slightly confused.. Why did you modify your e30 rear end? Maybe I am reading this funny.. Did you use a rear cover from an e30 rear end on a e36 rear end and then make the speed sensor fit?
        • 37833
        Just do yourself a favor and sell the E36 diff. Use the funds to buy an E30 diff.
        Grover Beach, California
        BimmerHeads.com
        • delt266
          • Apr 2011
          • 32
          I mean is it really that much of a pain in the ass to make work? Shipping this bastard is more irritating to me than building or modifying something to work..
          • Kershaw
            • 11822
            300 shipped for the diff to md?
            :D
            AWD > RWD
              With a bunch of work you could use that differential. But you'd be taking out a 3.73 (manual transmisstion) or a 4.10 (auto transmission) and replacing it with a 3.23. I suppose you'd get better gas mileage, but acceleration would suffer quite a bit.
              • delt266
                • Apr 2011
                • 32
                :D
                It needs another rear cover as the mount arm is cracked. You arrange shipping.
                • delt266
                  • Apr 2011
                  • 32
                  Well the whole M3 engine, trans, and diff would go in, so the ratios would be from the 1995 car. The ratios that you mentioned, were you referring to the stock e30 differential that's already in my 89?
                    Okay, if swap in the entire M3 drive train, then it would be worthwhile to convert the M3 differential.
                    • SpecM
                      • Oct 2005
                      • 4531
                      Really, just use an e30 or e24/e28 diff. There are 3.25 lsds available that are esay. Its more trouble than its worth to make an e36 diff work.
                      Sent from my Ally using Tapatalk
                      1989 cirrisblau-metallic 325i
                      • nrubenstein
                        • 3148
                        You would have to modify your subframe to make the E36 diff work. The way the front case attaches is completely different.
                        2002 BMW M3 Alpinweiß/Black
                        1999 323i GTS2 Alpinweiß
                        1995 M3 Dakargelb/Black
                        - S50B32/S6S420G/3.91
                        1990 325is Brilliantrot/Tan
                        1989 M3 Alpinweiß/Black
                        • Wanganstyle
                          • 2828
                          Garey
                          This is a very extreme way to handle this.
                          Conversion to a dual ear diff is only needed for crazy power in a E30, done pretty often to E36/7 Z3........google search "randy forbes" dual ear z3 and you will find this common mod to the z3's that like to tear out their sheetmetal.
                          Garey; you could have just plugged in the E30 speed sensor or a newer e30/z3 speed sensor into the e36 cover and pnp into your harness. This is often done, easier than machining- just swap the sensor or the chopper wheel- you had them in your e30 diff!!!!
                          speedo gear presses right on to the lsd unit.
                          Someone with your skills should surely be able to swap a ring and pinion?
                          if you reference the OEM bmw TIS for e30 M3, there is full factory instructions on how to replace the gearing and set it. One can easily remove the guts of any USA side 188mm E36 M3 diff and install it into any E30 188mm case.
                          so if you have a E30
                          and you have a E36 LSD, and you want the ratio and the LSD in your e30:
                          1. gut e30 diff
                          2. gut e36 diff
                          3. install e36 guts into e30 diff shell with proper OEM BMW speed sensor ring (chopper wheel) and genuine proper length speed sensor.
                          then you can install it into your E30 :)
                          How do you think my E36M3 has a 4.10 final drive gearing and TORSEN LSD in it :)
                          • Wanganstyle
                            • 2828
                            Misconception:
                            the OP is installing a M3 entire driveline into his E30, along with the ZFsg310 transmission
                            5th gear in a e36m is = 4th gear in any 5 speed E30 with Original e30 factory gearbox.
                            3.15 is paired with a 1:1 SG310
                            3.73 is pared with a 0.81 (overdrive)
                            Doing the Math and Comparing the 2 with equal tires, redline, etc:
                            If running a ZF M3 gearbox the 1:1 5th gear, if you wanted to have a crusing rpm similar to the stock E30 5mt with 3.73, you would either want a 3.07 or 2.93 final drive
                            The stock BMW M3 5 speed e36's had 3.15 or 3.23 final drives; paired with a 1:1 5th gear both are shorter than the stock E30; would spin @ higher rpm on the freeway.
                            • M-technik-3
                              • 18946
                              Quoted for the truth.
