I'll be switching from my current 3.73 to a 3.25 from an e28 here in the next couple of weeks. I've read that changing the rear cover and stub axles to the e30 medium case units will allow this swap. Should I be changing any seals as I swap the stub axles? The diff I bought is "leak free." When popping out the old axles, could the seals be damaged, or are they further internal? Thanks for some guidance. Also, what method have you used to pop these out?
Question About Changing the Stub Axles
Stub axels pop out w pry via screwdriver. Other than cleaning the seal area up, no need to change seals- its designed to allow stub axel changes all day without seal impact.OBD1 M54/M52TU swap as a M50b25
S50'd
Originally posted by TDE30What is this faggy shit I have happened upon?Originally posted by slammin.e28I can always live in a M3. Can't M3 a house.Comment
