haha thanks george. I will look this up on netflix now. Some younger friends of mine (16-17) didnt even know who wu tang was.
Rubbing Issues, Short shifter installed!
... driveshaft balancer. I'll concede the driveshaft on e30s don't need it, but it's for the driveshaft.
Nevermind the fact inline sixes are not perfectly balanced. More balanced than inline fours or V6s, but far from perfect.Comment
Im about to change my clutch, guibo, csb etc... I will remove mine as well
One of the best threads you will ever read
http://www.r3vlimited.com/board/showthread.php?t=221813
Nice trailer of my e30
http://www.youtube.com/watch?v=TTjtG...e_gdata_player
If i sold you something please leave feedback here
http://www.r3vlimited.com/board/showthread.php?t=217142Comment
Okay r3v, confirm my suspicions here.
I got the SSK kit from Blunt, didn't get enough time to install it myself since I've been super busy with work. I took it to this BMW/Mercedes place to have it installed, now my reverse gear won't go in and it feels like the "click" to engage reverse is all the way to the passenger side.
Did they install the selector rod on the wrong side of the assembly?Last edited by DatUtahGuy; 07-26-2011, 06:07 PM.YOUTUBE: AR Perez
- - -If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30Comment
the garage you took it to is obviously is DOING IT WRONG!my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blueComment
Yeah I'll have to go back and see what's what, but I don't know if the problem is the selector rod being on the wrong side of the assembly or the shifter lever being backwards, as in need to rotate 180 degrees...YOUTUBE: AR Perez
I have the AKG shift rod, but have not installed it. It is just too hot out right now.
I have the Z 3 1.9 in the car now and it used to rub on the balancer. When i had the driveshaft rebuilt i never reinstalled it. No issues here.
I will be replacing it with the Z4 M coupe one when i do though.seien Sie größer, als Sie erscheinen
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Schwarz3, does it run when moving? Something sounds like it is binding up. make sure to check if the selector rod needs to be bent or anything like that. i was lucky to have a lift and a buddy so i could work out all the kinks and get it just how i wanted my shifter.
3 pedal club
200,k+ club
cabrio club
port-matched- polished- purring www.BMWpark.org
</div>
linux since 1999Comment
I'm sorry I don't understand exactly what you are asking? Does what run when what is moving?Schwarz3, does it run when moving? Something sounds like it is binding up. make sure to check if the selector rod needs to be bent or anything like that. i was lucky to have a lift and a buddy so i could work out all the kinks and get it just how i wanted my shifter.
The thing is that the shifter won't engage reverse because the "notch" that is supposed to be to the drivers side, I can feel that on the passenger side. I don't know if that makes any sense, it's hard to explain I guess.
I was thinking of removing my harmonic balancer instead of bending the selector rod.YOUTUBE: AR Perez
Google this stuff before you start posting threads.I just installed a z4 short shifter and new bushings from Mr. Blunt. I bent the selector rod as needed and it still rubs slightly on the metal "balancer" (whatever you want to call it). I can either keep bending the selector rod or can i just remove the metal thing? I want to also upgrade the selector rod to the AKG one but i cannot bend that one. Opinions please.
Also z4 shifter feels awesome, it is really notchy and much shorter then the previous slop oem one i had before. I would recommend it to anyone, Also didnt have to remove the driveshaft in the process :D Thanks Blunt!"Do what you love, and love what you do" -Ray BradburyComment
