1987 325E 5 sp. w/LSD What ratio is common?
  • kayak
    • 708
    My 5 speed 1987 325E has an LSD. Does anyone know if all 87 5sp. 325E had the 2:93 ratio LSD or are there other LSD ratio possibilities for this year? LSD is on plywood under the car presently- have not yet tried to clean the metal tab with numbers of the serious rust as of yet. Will pull it out soon but I do have a lot of rust on the ID metal tab.
  • Jafxod
    • May 2011
    • 1301
    Theres alot better change its not an LSD and just an open diff. Check it out.
    • LJ851
      • 7919
      all Es have 2.93 or 2.73 . scrape off tab and you will know.
      Lorin
      The M30 is God's engine.
      • Genoknox
        • Jun 2011
        • 4
        how much scraping? i went to town on the tag and still couldnt see anything?
          • 37832
          An 87 will definitely have the 2.93 ratio diff. LSD was optional but standard on the 325eS.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • The Humjet
            • Jun 2010
            • 528
            My 325e had a 3.15 open diff in it. If you wanna know of its an LSD or not just jack up the rear end, spin one wheel and if the other spins on the same direction then you have an LSD.
              • 37832
              They must have had different options in Aus. We got no 3.15 diffs here.
              Grover Beach, CA
              www.BimmerHeads.com
              • TobyB
                • 5264
                2.93 LSD for Canadian market... 2/86 build date
                t
                • yeaseth
                  • Jul 2011
                  • 302
                  my ES had an LSD and it locked up better then the one I now have in my I
                  benvideoproductions.com
                  http://www.youtube.com/watch?v=617yNrOrRfo&
