I need a new trans...advice please/ auto to 5speed.
  • Tismael711
    • 791
    My auto trans in my 325ic is slipping....when i step on the gas the engine roars but the power isn't being transferred to the wheels. BMW tech who does work on the side says the trans is shot. I plan on putting in a 5 speed instead of going back to auto. What's the best 5 speed transmission available for an 88 325i convertible? What parts should i buy new...ie..slave and master cyclinder....driveshaft? pressure plate? What parts can i buy used?
  • reelizmpro
    • 9559
    Getrag 260 found in all 325's. Get one from a 87-91 325i and use a new clutch kit, driveshaft, slave cylinder and guibo. You can use a used flywheel from a manual trans car.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • LJ851
      • 7919
      Go to junkyard, get pedal cluster ,clutch switch + wiring ,etc. Get a 87 or later gearbox if you can. I converted my '89 , it is a totally different car now.
      Ive got a single mass flywheel if you need one. $60 shipped.
      Lorin
      The M30 is God's engine.
      • Tismael711
        • 791
        Thanks for responses. I found a trans and related parts from an 88 is, 157k.
