Best Clutch for E30s?
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    About to purchase a clutch replacement kit for my E30 and I wanted to get some experience opinions on the best bang for the $ when it comes to what clutches are out there for our cars.
  • Mike 91 318ic
    • Jun 2004
    • 429
    I have a Sachs sport clutch in my car which I'm very pleased with. Most say it's over kill but I got such a good deal on it I couldn't pass it up.
    M
    • RobertK
      • Jun 2005
      • 5864
      What's the difference between the Sachs Sport Clutch and the regular Sachs Clutch kit?
      • robweenerpi
        • 46
        Probably just friction material with a slightly higher temp range and a stiffer pressure plate.
        • RobertK
          • Jun 2005
          • 5864
          Where is the best place to find the Sachs sport clutch?
          • AdamF 88iS
            • 2051
            The Sachs Sport is very expensive, and has a light weight aluminum core with a higher clamping force.
            Standard 325 clutchs last forever, and should be fine. If you're really worried about it you can use an M3 pressure plate which has a little more clamping force.
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
            • Rob
              • 8166
              hmm, this seems like a technical question, maybe it belongs in the TECHNICAL FORUM
              BEERTECH
              • RobertK
                • Jun 2005
                • 5864
                Where is the best place online to purchase a clutch?
                • robweenerpi
                  • 46
                  www.bimmerworld.com
                  • Jon325i
                    • 6934
                    Just for the record, the stock clutch BMW put in the 6 cylinder E30s is robust for the cars' output potential. I've talked to veteran BMW mechanics and they feel the stock clutch is good for approx. 220 horsepower. If your motor is stock or even a 2.7/2.8L stroker, an OEM clutch should work just fine for your needs. If anything, spend the money towards a lighter flywheel. You could probably have your stock flywheel machined down a few pounds for under a $100. I have used a Metric Mechanic flywheel (stock unit shaved to ~13lbs.) and it will set you back $250.
                    Here's a new clutch laundry list:
                    clutch
                    pressure plate
                    throwout bearing
                    rear engine main seal
                    flush tranny fluid
                    Guibo (flex disk)
                    Options:
                    lightend flywheel
                    short shift kit
                    Sounds like a lot, but my logic is: if you have it all apart, why not address other things while you are at it (unless you like dropping the gearbox every weekend).
                    Jon
                    Rides...
                    1991 325i - sold :(
                    2004 2WD Frontier King Cab
                    RIP #17 Jules Bianchi
                    • onenicebimmer
                      • 139
                      I have the following set-up, and I like it:
                      Sachs HD clutch disk
                      SPEC stage 1 pressure plate (slightly stiffer than stock)
                      OEM throw out bearing and seals
                      Redline fluid
