Best Diff ratio for autotragic
  • scottinAZ
    • Dec 2009
    • 1312
    I have a 4.10 open diff for my cabrio project, but am wondering if a 3.73 or other ratio would be more beneficial. I am looking for a good compromise between mileage and performance.
    I saved 15% on my Bimmer parts by switching to ...
  • LJ851
    • 7919
    Keep the 4.10. The autotragic gearbox has a mega overdrive so the revs are pretty chill on the highway. Anything less is pretty sluggish.
    Lorin
    The M30 is God's engine.
    • Aus E30
      • Jul 2009
      • 478
      Bumped for a hijack question.
      I'm yet to take a look what diff I have on my Auto (89 320i 4 door) but depending on that outcome, is the 4.10 the best to get faster low end acceleration? I'm not bothered about high freeway revs or losing top speeds. Just improving off the line speeds.
      Your signature picture has been removed. Refer to the Signature and Avatar Guidelines in The Rules.
      I <3 dead naked girls.
        • 37833
        Automatic cars are suck dogs I couldn't imagine having anything but a 4.10.
        Grover Beach, California
        BimmerHeads.com
        • ZM Blue Devil
          • Dec 2006
          • 13836
          this or you can track down a 3.9xLSD
          Levent
          %20levent@gutenparts.com
          Ladies:
          • Aus E30
            • Jul 2009
            • 478
            Ok. Just checked it out and my tag reads "4.45 392"
            So does that read as a 4.45? So to get faster acceleration I need to go into the 3.x's? Or is 4.45 the shortest/fastest already?
            • 325ix
              • Aug 2009
              • 7783
              The larger the number the shorter the gearing and therefore the fastest acceleration. So, yes 4.45 is the best, unless there is something closer to a 5.xx.
              • Wanganstyle
                • 2828
                4.45 is one of the shortest common ratios; its paired with auto 2000cc M20 because the 2000cc needs the gearing muti-plier to move.
                your 2000cc e30 m20b20 has a 168mm 4.45 final drive unit. In usa, the 4.44/4.45 168mm is the highest numeric number avail; there may be BMW motorsports catalog high ratio units for 168mm, I know for 188mm they have 4.88 avail (very expensive, but I know where it is on hand in stock in AUS).
                You could install a 188mm rear diff plug and play as many others have done in their m10/m42 powered e30's; you would gain about 15 lbs to the rear axel on the larger size diff, but would be able to have access to 188mm lsd and more durable gear set if you plan on increasing the power of your e30
                your best bet would be to change tires to a smaller overall diameter to reduce the final drive ratio - tires are your last gear!!!
                • Aus E30
                  • Jul 2009
                  • 478
                  Thanks for such a detailed response! hmm..Info for thought.
