I am replacing my rear rotor hub and wanted to know if I needed a new bearing, sounds like its a PITA so If I dont need to I dont want to
New rear rotor hub, do I need a new bearing?
Tags: None
yes. you are almost guaranteed to destroy the bearing when removing the hub
Originally posted by ROLLingKINGi have a bronzit and plan on making it look sweet.Originally posted by slammin.e28Moral of this story?
If you drive your e30 on stairs, you're gonna have a bad time. -
Why do you need a new rear hub? stripped threads?
If you are replacing the hub, then you need to remove the bearing. You may as well replace it with a new one while you are at it. You risk damaging the bearing if you aren't paying attention to where the force is applied when pressing it out (if you only put force on the inner race for example)Comment
Nvm, bearing is still in really good shape. And I don't even want to say why I need to replace the rear rotor hub....Comment
Replace the bearing. Even if it looks good I promise you it's destroyed. I give it a month before it fails.
If you drive your e30 on stairs, you're gonna have a bad time.Comment
