Which diff do I have?
  • nefarious7907
    • Jan 2005
    • 1170
    I dont know which diff I have, I know that all of my burnouts have been with both wheels and the pics I have seen of LSD's have had miniture fins on the diff cover. Mine has the smallish fins on it, but I dont want to take off the cover to find out but I know it needs the fluid changed. Is there anyway to tell diff from diff?
    http://www.cardomain.com/ride/657387
  • erik325i
    • Jan 2005
    • 3567
    Look at the tag on the diff. You will have to clean it first, but if it is LSD it should start with "S" then the ratio. For example, mine says S 3.73 then some other numbers. If it does not have the "S" , then it is open.
    Also, lift up the rear end and spin one wheel. If the other wheel spins the same direction, it is a LSD. If the other wheel spins the opposite direction, it is open.
    • nefarious7907
      • Jan 2005
      • 1170
      thanks for that info, I hadnt seen anything on here about that before. I will check out pretty soon. thanks
      • clutterbucker
        • Jun 2004
        • 481
        funny...my 325i peels the outside wheel around hard corners when accelerating, but when i put it up on the stands and spun one wheel, the other didn't move in the opposite direction.
        - 2000 Audi S4 Stg 2 (sold)
        - house (bought)
        - 1997 Civic Hatch (shaky but driveable)
        - 2010 Sportster 1200 Forty Eight Ed. (vroom)
        - 1991 318is S50B30 (TBA)
        • Digitalwave
          is a poseur
          • 6279
          Did it move at all? It should move in the same direction if you have an LSD.
          RISING EDGE
          • boom-monkey
            • 1104
            Just because you can leaves 2 skidmarks, whether drifting or with a burnout, does not mean you have an LSD. There are several variables that would cause both wheels to spin.
            • clutterbucker
              • Jun 2004
              • 481
              sorry, when I said it peels the outside wheel, I meant it peels the inside wheel only, like an open diff would. But when I spin the wheel, it doesn't move in the opposite direction.
              Just thought it was wierd.
              - house (bought)
              • Digitalwave
                is a poseur
                • 6279
                Well an open diff will either spin in the opposite direction, or not spin at all.
                RISING EDGE
