88 eta trans in an 88 i?
  • jw 325ic
    • Sep 2006
    • 1360
    So my 88 325i trans took a shit...R-1-2 are out so I was going to swap the gears from the eta trans into my bell housing. But i was reading the thread on swapping g260s and this one has the shallow bell housing like my i trans so i think the throw out bearing will work. I also have the driveshaft and guibo. The only thing i dont have is the shifter (which is straight) but i have mine which has the bend. Will this work? Thanks in advance, trying to do this tonight/tomorrow.
  • SpecM
    • Oct 2005
    • 4531
    its the exact same trans, just swap the whole thing
    1989 cirrisblau-metallic 325i
    • jw 325ic
      • Sep 2006
      • 1360
      are you 100% on this? not trying to question your knowledge on the subject but when reading this thread: http://www.r3vlimited.com/board/showthread.php?t=109919 , and when looking at the shifter arms at the yard, the dogbone arm is straight where mine is bent and i think the linkage is longer on the e. im not worried about the driveshaft or the mating to the engine, i know itll mate and the DS will work with one i have, but the shifter...thanks for quick response!
      • jw 325ic
        • Sep 2006
        • 1360
        anybody?
        • Rigmaster
          • 3464
          same
          100% sure
          The only thing I'd confirm is the size of the output flange- as long as it's the same as your "i", then you're golden.
          I don't think it would/should have the larger flange/guibo, but if it does you'll have to do some mixing and matching to make it work in your car.
          • jw 325ic
            • Sep 2006
            • 1360
            same
            100% sure
            awesome, thank you sir! it is the bigger flange but i have the DS and guibo for it so im not worried about that. its the shifter im mainly worried about.
              • 37834
              You can use your complete shifter setup.
              Grover Beach, California
              BimmerHeads.com
              • jw 325ic
                • Sep 2006
                • 1360
                awesome. thank you good sir!
