Differential output shaft size difference, HELP!
  • DTFE30
    • Feb 2011
    • 471
    So I received my S2.93 differential from blatant last weekend and I have it all bolted up to my 1985 325e. When I started bolting up the half shafts I realized my flanges were way smaller than the flanges on the S2.93. Is this because the S2.93 is from a late model with ABS? Can I simply change the output flanges with my old ones? or should I buy new half shafts to match up with the diff? Any help here would be greatly appreciated.
    • 37834
    Sounds like the diff he sold you has the wrong flanges?!
    You can swap yours in to it, they just pop out of the diff with a screwdriver or prybar.
    Grover Beach, California
    BimmerHeads.com
    • DTFE30
      • Feb 2011
      • 471
      do I need to remove the 6 bolts on the side of the diff behind the flanges before I pry them off?
        • 37834
        Nope.
        BimmerHeads.com
        • DTFE30
          • Feb 2011
          • 471
          Awesome. Thanks for your help. How are the headers?
            • 37834
            Look good man, should be getting them on within a week or two.
            BimmerHeads.com
