SSK for ix made easy.
  • kansas-ix
    • Jan 2004
    • 1600
    I used the z3 1.9 as referenced here for comparison of ix and z3 1.9
    using this simple metal bottle cap from a 64oz growler of beer, from (free state brewery) any will do though, Drill out the center of the cap to the edge, and then using the dremel again grind down the lip on the outside of the lip.
    then place the now metal ring in the shift carrier and work it down to the bottom.
    Then place in shifter, now you have just the right distance so the shifter doesn't bang on the t-case and the plastic cup is still inside the carrier.,
    See the nice distance below: As there is just enough space for the linkage to attach:
    Ta dah!, Done, No need to bend the linkage or anything else, goes into gear great notchy but smooth.
    E30 325ix 62k
  • Jordan
    • 12916
    Uh... the cup isn't locked in, and whill pop up and out when shifting.
    :loco:
    https://mtechniqueabs.com/
    • kencopperwheat
      King of Kegstands
      • 14396
      ^^ What he said.
      Was the lever hitting the driveshaft or what?
      Originally posted by Gruelius
      • kansas-ix
        • Jan 2004
        • 1600
        :loco:
        quite possible but, the metal clip I put in is jammed in there and prevents the bottom of the shifter from pulling up. It works, may be temporary but works.
        And Ken yes a 1.9 z3 shifter will hit the transfer case if you just stick it in there, in fact that is what caused all my long problems to begin with. IE shift carrier breaking.
        E30 325ix 62k
        • Digitalwave
          is a poseur
          • 6302
          Now thats some ghetto Kansas pothead engineering.
          RISING EDGE
          • trent
            I would call you SUPER HACK.
            • kansas-ix
              • Jan 2004
              • 1600
              Nail on the head; strike and strike again. :D
              "Dank" engineering, you are correct sir!
              E30 325ix 62k
