clutch stop?
  • cro320
    • 147
    clutch stop?
    I have one question related to aftermarket clutch stop.
    My car shifts like a dream in ususal driving, but shifting from 1-2 gear is pain in the ass...it stalls, jumps...even if I use the clutch very gently it's almost impossible to get smooth shift.
    I was thinking of getting clutch stop to minimize that
  • blueapplesoda
    • Dec 2005
    • 1904
    Clutch stops are garbage. They are for pussies.
      A cluch stop isn't going to help wih the 1-2 shifts. That could be a problem with the clutch, or more likely a problem with the engine. If the idle is a bit rough and/or there is a hesitation when opening the throttle intake leaks and/or other problems with the engine management system are art the root of your difficulties.
        • 34844
        I like having a clutch stop, but I agree that it's not your problem. a clutch stop just saves from wasted clutch pedal movement, it's not going to change how the car shifts.
        also, don't buy a clutch stop. you can make one from a bolt, 2 nuts, and a rubber bumper off the bottom of a chair. you can buy all of this stuff for a couple bucks.
        • cro320
          • 147
          clutch is almost new, last year changed and car is idling perfectly
          • ron1999
            • May 2007
            • 122
            what he say:
            clutch stop has nothing to do with shifting gears....
            • SimplyDope
              • 1335
              Let me know what comes of this, OP. I have a new clutch and it feels less solid in 1-2 than in 3-5. Feels rubbery almost (hard to figure out friction point, although it holds fine on small inclines). FWIW, it's the single-mass conversion in an m42.
              • SimplyDope
                • 1335
                Bump.
                • russianman92
                  • May 2011
                  • 53
                  Check your master and slave clutch cylinders and make sure u got enough fluid. 1st and 2nd are the roughest gears. That said shifting higher is easier but If your clutch isn't engaging all the way 1st to second could be a pain and possible engine stalling or rough shifting. but the last gears wouldnt be so rough as its easier to shift.
                  • Jaxx_
                    • Dec 2009
                    • 1880
                    It could possibly be synchro issues? Does it ever feel worse in the morning before the transmission fluid has warmed up?
