auto to 5 speed sway would an eta work as a donor car?
  • Spencer
    • 767
    I have a 325i. Would an eta have all the parts needed for an auto to 5-speed sway? If not what parts would i still need?
    TIA,
    Spencer
  • Digitalwave
    is a poseur
    • 6298
    Yes, but you will have to use a 325i clutch kit/flywheel/throw out bearing.
    You might also have to use a 325i driveshaft and change the output flange on the tranny, but I am unsure on that.
    RISING EDGE
    • Spencer
      • 767
      Thanks TJ.
      you might also have to use a 325i driveshaft and change the output flange on the tranny, but I am unsure on that.
      Can anyone confirm this??? I was thinking of using an eta because the one i'm looking at has a new driveshaft. So if i'll need to replace it anyway there would be no point.
      Spencer
      • Digitalwave
        is a poseur
        • 6298
        Now that I think about it, the eta driveshaft WILL work because I remember everbody telling me I could use an eta driveshaft on my car... but I might of had to change the output flange on the tranny.
        RISING EDGE
        • Spencer
          • 767
          Would changing the output flange on the tranny be a big deal? I could find a 325i parts car if i had to. An F-150 made a left turn in front of my friends nice 86 eta so if he can buy back the car it would be cheap.
          -Spencer
          • Digitalwave
            is a poseur
            • 6298
            Its not hard, it just requires a special 30mm (I believe) thin walled, deep socket.
            RISING EDGE
            • rs4pro3
              • 5808
              The output flange swap depends on the year eta, 87 got the larger flange. But ya the eta driveshaft will work just fine, just get the lighter I flywheel,clutch, and bearing liek TJ said. Everything else bolts up just fine.
              85 325e 2.7 ITB'd stroker
              • Digitalwave
                is a poseur
                • 6298
                I forgot to add that if you use the pedal box from a car that didn't have an airbag on a car that has an (or had) an airbag, you are going to have to do some creative hacking of the 2 pedal boxes in order to support the steering column.
                RISING EDGE
                • RobertK
                  Kicked cancer's ASS.
                  • Jun 2005
                  • 5864
                  Everything from the ETA should swap right out no problem, even the flywheel only it's much heavier than the I flywheel but technically it all swaps out.
                  • BimmerToad
                    • Sep 2004
                    • 1537
                    Are the 325i and Eta Getrag 260s the same internally? The 260 I'm using for my M50 swap has a bigger output flange than the 325i flex disc I bought, so it sounds like I have a 260 from an Eta.
                    San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
                    • Digitalwave
                      is a poseur
                      • 6298
                      Besides the eta having 2 addition sensors on the tranny, they are the same internally (save for the clutch and flywheel/to bearing of course). You can change the output flange to a 325i unit.
                      RISING EDGE
                      • BimmerToad
                        • Sep 2004
                        • 1537
                        Yeah, it looks that way from the ETK. The Eta 260 was upgraded to 325i spec gears and synchros (same part #s) from 4/86 and on, and got a bigger output flange at the same time.
                        So bigger output flange on an Eta 260 = stronger synchros.....
                        Time to swap the flanges..... 8)
