I would remove the balancer like others have said. However that won't make up for the spacial difference created by removing the balancer, might loosen the csb to allow the driveshaft to move forward.
					guibo question
 got it. my new bolt and nuts will be in monday. when i was under there i also noticed my damn tranny mounts were sooo messed up. motor mounts 2.lol always somethinLast edited by ROLLingKING; 09-18-2011, 05:49 PM.m20 is plenty. im simply a drifter.
 build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510Comment
 Thanksm20 is plenty. im simply a drifter.
 so ive been trying for 2 days now..really 2.5 and me and my boys cant get it. The balancer is in the way and the shield wont let any open ended wrenches hold the nut. We were able to get the bolt started on the nut with our fingers but I cant torque em down. Its going on 3hrs now!
 Any suggestions on what to use between the transmission and the back of this STUPID shield??m20 is plenty. im simply a drifter.
 pleeease help..ive got ony 1 bolt to tighten. Its the one that holds the driveshaft flange to the guibo..The nut is on the transmission side and the bolt facing the driveshaft.
 We have tried open ended wrenches of many sizes..and other makeshift tools but its not tight enough to drive yet.
 I did get my motor and tranny mounts done tho! this is the last piece.lolm20 is plenty. im simply a drifter.
 right i understand the concept..its getting a tool behind there to hold the nuts on the other end of the guibo.lol
 Does anyone else know what im saying. taking off the driveshaft isnt the solution. How do I get a tool back there to get a grip on the nut behind the balancer! lol
 stop telling me to remove the driveshaft if I cant get behind it. Im just trying to tighten the bolt that fell out.lol
 im probably pissin u guys off but its really hard to get the nut to stop spinning. Even if i want to get rid of the shoeld I have to hold down a bolt in the back. If i could do that i would have my shit all tight by nowm20 is plenty. im simply a drifter.
 I'm trying hard to understand this. In my experience the bolts coming from the tranny flange are press fit into the flange along with the balancer so I never had to hold a nut behind that area. All you have to do is line it up and then put the nuts on from the DS side. If yours are all "free" bolts and nuts, I don't know what to say...I've never seen that before. Is the tranny brace in the way at all?Comment
 here is your solution:
 buy 30mm thinwall socket; local matco or snap on will have, you can also order it online.
 1. remove driveshaft from guibo
 2. remove guibo from transmission output flange
 3. remove transmission output flange from G260 with your new 30mm thinwall socket
 4. remove studs/ extra balancer assembly; toss balancer in trash.
 5. order 6x new guibo bolt/nuts (newer non pressed in style)
 6. re-install transmission output flange
 7. assemble and never deal with this again.
 If you were local I'd tell you to take car to Ryan G Garage, he is an Ace at this puzzle.OBD1 M54/M52TU swap as a M50b25
 To all of those that say that the balancer is mounted wrong
 Brand new unit from BMW
 There are more than one model...
 Also since the CSB can move quite a lot and hide the fact that the locking
 collar on the drive shaft might be tightened and need to be loosened.
 that way the drive shaft will adjust...
 if u look at what cabriodster87 posted..that diagram shows you how my driveshaft has the bolts facing the back and the tranny flange is going the opposite direction. (except contrary to the diagram, my guibo is inside that shield.)The opposite bolt direction tho is probably to pull the guibo in both directions keeping it from flexing..I'm trying hard to understand this. In my experience the bolts coming from the tranny flange are press fit into the flange along with the balancer so I never had to hold a nut behind that area. All you have to do is line it up and then put the nuts on from the DS side. If yours are all "free" bolts and nuts, I don't know what to say...I've never seen that before. Is the tranny brace in the way at all?
 I want to try and loosen the nuts i see but then if the bolt starts spinning in the back, now my tranny is loose..cause an open ended wrench IS NOT fitting between the shield and tranny...i mean it fits, but doesnt reach the recessed nuts or bolts from the back.m20 is plenty. im simply a drifter.
