guibo question
m20 is plenty. im simply a drifter.
build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510 -
Hey cornopoulos
I just realized the tranny flange sits in front of that shield so I dont think removing the shield will be that simple. The tranny will then be in the way.
But those bolts that are in the pic..the bolt head is on the backside of the guibo. Making it in my case not possible to get any wrenches on it.. Do those bolts spin if i try and take the nuts off of them? If they do then that would be another bolt I cant tighten which i dont need at the moment.lolm20 is plenty. im simply a drifter.
build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510Comment
No I agree with what you are saying. I was just instructing the OP how to attach the guibo in the correct order or at least the way I found the easiest. There seems to be some discrepancies on where that shield is located though. Like E30GUS stated, those bad boys should be pressed in and should not spin. Maybe there are more differences in this design then I first anticipated. Either or in my case with an 87, this process to around 15 minutes to complete once all the necessary steps to get there were taken.Hey cornopoulos
But those bolts that are in the pic..the bolt head is on the backside of the guibo. Making it in my case not possible to get any wrenches on it.. Do those bolts spin if i try and take the nuts off of them? If they do then that would be another bolt I cant tighten which i dont need at the moment.lolComment
the flange slides right off after you remove the retaining nut with a 30mm thinwall deep socket.... slides right off-
Please stop pretending you have done this before & posting wrong info.OBD1 M54/M52TU swap as a M50b25
Please learn how to read before you talk shit. He clearly stated that the bolts are pressed in to the flange and need to be hammered out.
Originally posted by ROLLingKINGi have a bronzit and plan on making it look sweet.Originally posted by slammin.e28Moral of this story?
If you drive your e30 on stairs, you're gonna have a bad time.Comment
now now..be nice
1..it makes no sense to hamer those bolts out..cause then they would spin.haha i got my bolt tight..got the guibo to move enough so i could fit a tool back there.
but there were a lot of ppl suggesting things and it sounded like they never actually did it with the balancer like that and they were just saying what they thought would work..check out my build thread and u will see what i had to go through for it to work..what a pain in the assm20 is plenty. im simply a drifter.
Mine looks the same as the above picture with balancer behind the guibo.
Also, try dropping the CSB before you attack the guibo. It'll give you tons more wiggle with the driveshaft.Comment
