Best LSD Diff Ratio?
    I want a diff that has good acceleration and will not effect my fuel consumsion much on the highway.
    329i
    Kind of hard to estimate w/o engine and mod info
    Originally posted by audiquattrot
    bimmers b4 b*tches....remember that.
    1990 Alpinweiss 325i - secret 500whp build
    2000 Audi S4 B5 Laser Red
    1990 Nissan 240sx - Drift Missile
    2006 CBR600RR
      An M50, chipped with a G260?
      REMEMBER: Be safe and have fun is Rule Number 1.
      The Epic Unbuild of Clint Eastwood
        A 3.64 with 23inch tires
        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
          There is no "best" diff, it's all about personal preference and compromises. What characteristics do you appreciate most and what is your driving style/driving conditions?
          If you don't feel like answering that, BMW's factory setups are generally a pretty good choice.
          Lorin
          The M30 is God's engine.
            2.65 final drive + 7 speed SMGIII transmission + S85 5000cc V10 engine is the "best" ratio. :P
            otherwise what is in the car OEM is pretty pretty good pairing :)
              i have a 2.8 stroker with a schrick 272 degree cam.
              My diff currently allows me to do 120Kph in 2nd gear.
              I wan't to wheel spin easier in second.
              329i
                what is your current final drive 3.73 ? OEM m20b25 is 3.73 stateside, if you are using G260 gearbox a 3.91 ratio would probably be the next bump up :)
                  Get a 4.10
                  - E30, DSM, Golf R, Mazda 3 Skyactiv
                    4.44 is the shit!
                    sigpic1984 318i Total conversion to a DIRT race car.
                    Check out our build on facebook @ www.facebook.com/brewstermotorsports
                      i dont know about a 4.10 or 4.44
                      this is not my specialty at all but my 2 cents is a 3.73 should be sufficient. and u wont be waay up in the rpm's at 80mph
                      you say you want to spin tires more in 2nd..do u mean in a straight line, like chirp 2nd?
                      cause a 3.73 in my stock/weak un touched m20 will slide in 2nd allll day. a 2.8 shouldnt have problems. whats your rear tire size/how sticky are your tires?
                      m20 is plenty. im simply a drifter.
                      build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
                        I'm not sure what ratio i have but i know it's not for acceleration.
                        I have Toyo T1R's and they are very sticky i think that is the problem with wheel spin anyway.
                        Hows your fuel ecconomy with a 3.73?
                        329i
                          I have 3.73 gears with a g260 and a stock m20b25. My car will do a little less than 60 mph in second (roughly 100Kph), so I doubt you have a 3.73, I'd say more like a 2.93. That's just my guess.
