IX Ring and Pinion - is it reverse cut? what diameter?
  • mechdonald
    • Sep 2011
    • 111
    I am working on a project and need to source a reverse cut ring and pinion gear with a small diameter ring gear. Searching for such information is difficult for something other than the typical Jeep/Dana stuff.
    Does anyone have this information... or know where I can find it? Or who to ask?
    Just to clarify... this is the front axle. And I am looking for a reverse cut ring gear with a diameter less than 7" - preferably around 6.5"
    Thanks.
  • Wanganstyle
    • 2828
    honda b/d series? b series ran counter clockwise
    • mechdonald
      • Sep 2011
      • 111
      good thinking... but I checked some pictures on Google and they aren't reverse cut. Here is a picture of the layout I need. Note the direction the teeth curve on the ring gear.
      I just need a smaller diameter setup than is available in all the North American market off-roading stuff.
      I am hoping the E30 IX front R&P will work. The ratio isn't too critical at this point, but something between 3.6x to 4.0x would be nice.
      • Wanganstyle
        • 2828
        what about subaru transmission front diff? it has a R&P also and is inside the trans.
        or try porsche front diff from AWD 911? one of those guys must be weird, as both engines spin clockwise; one is AWD rear engine, one AWD front engine.
        • mechdonald
          • Sep 2011
          • 111
          I just checked with a SubaruGears.com and it looks like we have something. They measured the gear and it is roughly 6.5" OD. I just have to check some other information now to make sure it will work.
          Thanks for your help,
          Dale
          • mechdonald
            • Sep 2011
            • 111
            Actually, looking more into things, the Subarugears.com stuff is to convert an aircooled VW to use Subaru transmissions. Subarus do not seem to normally have reverse cut R&P. More research required.
              • 34847
              I *think* ix front diff R&Ps are still cut the same as a rear diff. if you think about it, it's turning the wheels in the same direction, but the diff is just upside down.
              I don't know how big it is, but my guess is small. it's smaller than a 168mm R&P for sure.
              • mechdonald
                • Sep 2011
                • 111
                I did some more digging on Google Images. This is from a thread on E30tech. It shows that it is reverse cut. Looks pretty small too.
                Getting closer to my answer I hope. What ratios did these come in?
                here is the thread
                  • 34847
                  3.91 and 4.10 are the only ones you're likely to find. you can get a 3.64 and 3.73 but they're euro only, expensive, and rare.
                  • mechdonald
                    • Sep 2011
                    • 111
                    I take it that the tooth count on the 3.91 would be 43/11?
                    • Wanganstyle
                      • 2828
                      you could also check with the toyota/nissan 4x4 setups
                      RB25det and DE and Rb26DETT also had a front bolted diff on engine, similar sizing as the BMW stuff.
