SSK: Selector Rod contacting Driveshaft- Safe to Drive?
  • SlamedIAm
    • May 2011
    • 318
    I understand how to go about actually solving the problem as far as removing the selector rod, bending it, and reinstalling it to clear the driveshaft/harmonic balancer. My question is that if driven, what if any damage is being done? Obviously the sound/vibration is obnoxious but is there going to damage the driveshaft and or other components of the driveline?
    I ask because I am attempting to drive home from school (Savannah GA) to Annapolis MD next week. I don't have an ideal place to perform this modification and I can't afford to pay a shop at the moment, especially knowing I can do it for free.
    If I can safely drive the car to MD I have access to a lift that should make the job extremely easy. All of that being said is this an issue of an annoying vibration that can be ignored over a long drive or is there great potential to cause serious damage?
  • kennyvb
    • 404
    Should be safe to drive. Does it make contact in every gear?
    '04 Toyota Sienna AWD (sold)
    '86 BMW 325 coupe (owned since 10/11)
    '05 Subaru WRX sedan (sold)
    '86 Subaru GL-10 wagon (sold)
    '98 Acura Integra GS-R hatchback (sold)
    • SlamedIAm
      • May 2011
      • 318
      Doesn't seem to hit in R. 2 and 4 are by far the worst with noticeable contact in 1 and 3. More so in first. I've barely driven it since it's become an issue so I haven't been anywhere to get it into fifth, which would clearly be the majority of a long trip. I'll test that out this evening and get back to you.
      • AnimalE30
        • Aug 2009
        • 266
        Is it a dssr or just the dinky stock one?
        Either way tho, I wouldn't chance it. I was left stranded when I ripped the joint off the transmission when the little pin didn't seat it self correctly. I was left with a 200 dollar towing bill and had to fix it outside the garage (couldn't get up the hill) at 2 in the morning when it was below freezing.
        Not the same issue, but your shifter is kinda needed to move about. Just throw down an Irish kreeper and get it done.
        • SlamedIAm
          • May 2011
          • 318
          Thanks for the responses guys. It looks like I might need a new CSB as well so I won't be risking it.
            • 34844
            remove the "harmonic balancer". it really doesn't do anything.
            • Jafxod
              • May 2011
              • 1301
              My short throw shifter hit one of the balancing weights on my driveshaft and i drove it anyways
