6 Speed Swap?
  • Digitalwave
    is a poseur
    • 6302
    Originally posted by Ritalin Kid
    Your top speed has more to do with your gear and differential ratio from what I understand. The higher the diff ratio the faster your acceleration is but your top speed is lower - the lower the diff ratio the higher your top speed is but your acceleration is slower.
    Not necessarily. A 4.10 has a higher top speed than a 3.73 in a stock 325i. The gearing allows the engines power to be used more efficiently against the terrible aerodynamics of E30's.
    RISING EDGE
    • RobertK
      Kicked cancer's ASS.
      • Jun 2005
      • 5864
      I stand corrected..
      So I know this is way off topic sorta.. but what is the top speed of a 325i?
      • rs4pro3
        • 5808
        IF you wanted close gear ratio's just go for one of the Euro dogleg E30 boxes. A lot cheaper and will bolt right in.
        85 325e 2.7 ITB'd stroker
        • kencopperwheat
          King of Kegstands
          • 14396
          You can find them for about a grand on s14.net usually.
          Originally posted by Gruelius
          • RobertK
            • Jun 2005
            • 5864
            Bolts right up eh? Is it a Getrag as well?
            • erik325i
              • Jan 2005
              • 3567
              I would prefer it just for the closer gear ratio.
              From what I've read, the Euro 6-speed found in the e36 m3s, are not close ratio. The first 5 speeds are pretty much the same. The 6-speed is just an extra high gear, probably to help gas milage.
              Here are the numbers:
              euro 3.2L 6 speed----------US 5 speed
              4.23 ---------------------------4.20
              2.51 ---------------------------2.49
              1.67 ---------------------------1.66
              1.23 ---------------------------1.24
              1.00 ---------------------------1.00
              0.83 ---------------------------
