I think the diff is no good but only under load. Is there a way to check the clutches for slippage without ripping the cover off?
What's a good way to check a diff?
Jack up the driver's rear wheel, take the parking brake off, and put the transmission in neutral. Then, using a torque wrench, see how much force is required to cause the driver's wheel to turn. And LSD in good condition will take better than 50ft-lb of torque before the wheel will turn.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
Jack up the driver's rear wheel, take the parking brake off, and put the transmission in neutral. Then, using a torque wrench, see how much force is required to cause the driver's wheel to turn. And LSD in good condition will take better than 50ft-lb of torque before the wheel will turn.Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.Comment
Post results if you will
Going to try mine this week. Its a fresh LSD the is smooth and locks predictably and smoothly.
Originally posted by Roysneon$5 shipped?Originally posted by MarkDYou are a strange dude, I'n not answering any more posts from you.Comment
I'll be doing this this weekend just to see how good my LSD is performing.'84 318i M10B18 147- Safari Beige
Turbo: 221whp/214ftlbs, MS3x flex @ 17psiComment
Guess I don't understand why this test is useful. Doesn't the LSD need a load to lock. So jacking up the car and doing what was said wouldn't place enough load to lock it IMO but maybe it does. Just having a hard time believing this test is really worth while. Maybe, meh
It works because one wheel is locked by it resting on the ground. So what you are measuring is how much force is required to cause the clutches to slip.
BTW: a new E30 differential should hold 65ft-lb before the clutches slip.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
aight, I misread your post then. I'm seeing the whole rear jacked up not just one wheel. lol Thanks for the clarification Jim
56 ft/lbs until it broke loose.'84 318i M10B18 147- Safari Beige
