84 m10 auto to manual?
  • andrewm
    • 456
    Well, it looks like I might be getting another e30. This time for a beater. I've spent about the last hour or two attempting to find out what my options are for swapping the car around a bit.
    It’s a 84 318i Auto. I cannot stand automatics. They are slow, unbearably so for an m10, and make me so depressed the only recourse for happiness is a rather unhealthy portion of bacon.
    I've discovered a few things about the options, but nothing too clear. Obviously I prefer a 5 speed due to the automatic having a 4.10 diff. If memory serves, the 318i 5 speed from later years does not bolt up? Any assistance on this would be fantastic as I'm looking at the car in a few hours
    Thanks!
    1987 Delphin 325e Sedan - Natalie
    1990 325i 24v
    1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
  • Jaxx_
    • Dec 2009
    • 1880
    you're looking for the getrag 240. I'm not sure on specifics as far as what driveshaft you will need.
    I'm not sure why you would prefer a 5 speed if an automatic has a 4.10? Either way, you can keep the diff if that's the concern. most, if not all, of the 5 speed 318i's from 84 will have 3.64 rear ends.
    I have been told that the bell housing from M42s will bolt up, but I haven't looked into it.
    With all that said, I've seen G240s in the area of $50.
    • Holland
      • Nov 2008
      • 7212
      M10 auto's are 3 speeds. Quite horrible.
      Originally posted by DEV0 E30
      • andrewm
        • 456
        Yea, I'm tempted to avoid it all together. I prefer a 5 speed so that I can have a taller 5th gear, I do a lot of interstate travel. I've heard the M42 swap as well, but no confirmation on that. Most likely not a lot of people waste their time on the 84-85 m10
        1990 325i 24v
        • Jaxx_
          • Dec 2009
          • 1880
          only the idiots. ;)
          • andrewm
            • 456
            I should fit right in there :)
            I'm really torn on it. I love e30s, and this is a well cared for vehicle. Low miles, but asking a bit more because of that. Just not sure if it's worth getting into a 5 speed swap.
            1990 325i 24v
            • jeffnhiscars
              • Jun 2011
              • 6011
              Idiot here !!
              IIRC the G240 bell housing out of an M42 is rotated (I think 15 degrees) so you have to mod the shifter to clear the cutout in the floor pan. Having said that, the change was worth it, especially if you enjoy mucking around under a car. My diff is a 3.46 and I doubt I'd change that. GL
              Alice the Time Capsule
              • Holland
                • Nov 2008
                • 7212
                Originally posted by jeffnhiscars
                Idiot here !!
                Why not source a 5 speed out of an 84, 85 318i? then there would be zero issues.
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  I was answering his question about the possible use of a later model G240 and was in no way encouraging it. In fact, if I was set on having a 5spd there is no way I would buy an auto trans car with the intent to do the swap. Get what you want in the beginning.
                  in other words, Im agreeing that IF he had the car and IF he chose to make the swap, definitely get the early trans
                  • Jaxx_
                    • Dec 2009
                    • 1880
                    i appreciate the information, even if no one else uses it.
                    • Smelser
                      • Feb 2011
                      • 633
                      I have a 5 speed, but i get a 100 lb weight break in my race class if I use the auto trans. how much more does an auto trans weigh?? and anybody still have one for SUPER cheap?? I hear talk that the drive shaft for auto and manuals are differant, is this accurate???
                      FOR JEFFNHISCARS.... whats that in your lines at the bottom bout the 65 bug?? send me a message, my wife has a 64 being restored, but we are short an engine. THANKS!!
                      sigpic1984 318i Total conversion to a DIRT race car.
                      Check out our build on facebook @ www.facebook.com/brewstermotorsports
                      • jeffnhiscars
                        • Jun 2011
                        • 6011
                        Hah..I caught that bug in HS so it is LONG gone but in the interest of helping a fellow Canuck, I do have my original auto tranny sitting in Florida (note Im in Charlotte). If you decide to snowbird we can try to work something out. Im the second owner and it worked flawlessly until I yanked it...and yes I have the drive shaft too :-)
