Anyone else find their UUC SSK to be sloppy?
  • rturbo 930
    • Dec 2005
    • 2625
    When I got my E30, the whole shifter assembly was completely shot, so I bought a UUC shifter, and installed it. I've driven it a bit, and found that it's sloppy, and extremely notchy (part of which is probably the trans fluid, but that's a separate issue). When I examined it, I found that when changing gears, the shift lever would move up, and forward. In other words, the ball of the shifter is sliding up on the lower bushing when I shift, instead of staying centered in the bushing. I hope that makes sense.
    I looked in UUC's instructions, and it said that a sloppy shifter could be because the snap ring is not in its groove, but it was, so that's not the problem. I'm pretty sure everything was installed correctly, so I doubt that's it. I measured, and when pulling up on the shifter, it looks like it goes up 4mm.
    Anyone else have this issue? Just wanted to check here first to see if anyone else had the problem and fixed it before I email UUC.
    When you installed the UUC shifter did you also replace all of the wear parts? Shifter cup ring, fore & aft shift console bushings, selector rod bushings, and selector adapter? If not, do that and see if you still have the problem.
    • rturbo 930
      • Dec 2005
      • 2625
      It's all new. New selector joint, linkage, and associated bushings, new carrier bushings, new cup ring, etc. Only thing I didn't replace is the rear carrier bushing, which is currently in the mail. The carrier doesn't move much though - 1mm (measured).
      • KenC
        King of Kegstands
        • 14396
        I used metal washers instead of the yellow plastic ones and it's super tight.
        Originally posted by Gruelius
        • rturbo 930
          • Dec 2005
          • 2625
          I got a DSSR with it, so that part of my linkage is super tight as well, I'm really happy with that part of the kit. It's just the shift lever itself giving me issue. The ball (outlined in red) is riding up on the lower bushing (in green) when I shift. Seems like the spring on top isn't strong enough, or something isn't installed right (doubtful, but I'll double check on Thursday).
          • AldcE30
            • 66
            those uuc ss are not inexpensive either
