Driveshaft Trans end Assembly
  • bobm123
    • 26
    Hey guys I'm new to this, so I apologize if this was already covered or is common knowledge. I tried searching the forum and didn't see anything, so here goes.
    Is this driveshaft installed correctly? ('88 325is manual). All the drawings I've seen so far show the bolts alternating front/back, but mine has all the nuts on the trans side. Is this normal? Does it matter?
    Thanks in advance,
    Bob M
    Nuts on the transmission side is correct when the transmission flange doesn't have pressed in studs.
    • irish44j
      • 2763
      ^ this
      beside the fact that you probably wouldn't be able to get the bolts through the transmission side anyhow, due to lack of clearance.
      Stage rally/rallycross e30 build/competition journal
      Track/street e21 build
      visit Condor Speed Shop
      visit Motorsport Hardware
      [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
      • bobm123
        • 26
        Good points, thanks for the info!
        • bobm123
          • 26
          Threaded or Non-Threaded?
          The reason I ask is that apparently 1988 325IS has a drive shaft with either a Threaded Flange (http://tinyurl.com/79gxrdc) or a Non Threaded Flange (http://tinyurl.com/84dgkad).
          The sales guy at Turner said it was really obvious which is which. Maybe so if I pull the old one, but that's not really practical for me since I have to do all this at a friend's house.
          Is there any way from the photos above (bolt orientation maybe?) to tell which I have? If not, does any one know when they changed over? Then I might be able to guess based on the manufacture month.
          Thanks,
          Bob M
            • 37832
            No driveshaft has a threaded flange. Some of them have a balancer on them with studs on the driveshaft side. Some transmission flanges have studs on the transmission side.
            Can you tell us what exactly you're trying to figure out here? Do you want to replace something?
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
              If there are nuts and bolt heads on the rear side of where the guibo is, you have a transmission output shaft with pressed in studs.
              • bobm123
                • 26
                Sorry to be so lame. I'm pretty new at this. Thanks for your patience.
                I'm trying to replace my driveshaft.
                If I understand correctly, the pictures above show that my transmission output flange does NOT have pressed in studs. Got it. Now armed with that information, which of the two driveshaft do you think I should order? The choices seem to be:
                1988-1991 E30 BMW 325i 325ic 325is - 3 bolt flange at flex disc is threaded
                or this one:
                1988-1991 E30 BMW 325i 325ic 325is - 3 bolt flange at flex disc not threaded
                Is it even possible to tell from the studs on the output flange? Do I need to look at something else?
                -Bob M
                  • 37832
                  Either one is going to work as far as I can tell.
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • brandonbio
                    • Jun 2014
                    • 70
                    I know it's been three years almost since this post, but I'm in the same situation right now. I need to replace my driveshaft on my '90 325is and I'm not sure whether to get the threaded or non-threaded one from tuner Motorsport.
                    Thanks,
                    or this one:
                    -Bob M
                    '05 ZHP - Mystic Blue Metallic
                    '90 325is - Alpine White
                    '85 535i - Zinnoberrot
                    • validius
                      • Mar 2015
                      • 161
                      Thanks,
                      I just took my drive shaft out. It was the non-threaded type. I'd get under the car and inspect what you have. If you have nuts on the end of all your bolts then you certainly don't have threaded anything right?
                      1987 325i Convertible
                      2015 Fiesta SFE: 1.0L of 'Woah, is that torque under 2k?'
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        For future reference, we remove those dampers on all drive shafts and never had a problem. Pull the studs out, remove damper, reinstall studs.
                        Also the orientation of the bolts don't matter so much as does the arrows on the giubo need to be pointing to the flanges. The giubo has "more meat" between alternating trisection, installing it in reverse will prematurely wear the giubo.
                        john@m20guru.com
                        Links:
