clutch engagement after manual swap
  • mkcman17
    • Jul 2010
    • 8240
    put together my manual swap, and after bleeding all brakes and clutch slave twice, clutch pedal still won't engage. there's minimal resistance, and the pedal stays on the floor. both masters are new, slave is used. clutch plate facing in proper direction.
    eta trans, single mass flywheel, clutch and pp.
    have not started car yet, only tested pedals for pressure and function.
    any ideas? i can put the car into gear, but trans stays engaged to motor.
    1989 LN106 Hilux / 3.0TD SFA
    1974 2002tii / stock
    2002 IS300 / 5spd LSD
    • 37825
    Did you bench bleed the brake master cylinder?
    Did you bench bleed the clutch master cylinder?
    Classic BMW Specialists
    Santa Clarita, CA
    www.BimmerHeads.com
    • mkcman17
      • Jul 2010
      • 8240
      turns out the power bleeder wasn't sufficient....needed to do a good manual bleed.
